Netflow on cisco 2800
Trung Minh
Hi Experts,
I have configured the netflow to gathering flow from my cisco 2800 as below:
interface GigabitEthernet0/0
description ### To VNPT_FTTH_20M ###
no ip address
ip flow egress
ip route-cache flow
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
interface GigabitEthernet0/1
description ### To KVP_ISW_G0/2 ###
ip address 10.126.125.6 255.255.255.240
ip flow egress
ip route-cache flow
duplex auto
speed auto
interface FastEthernet1/0
description ### To KVP_FW1_P3 ###
duplex full
speed 100
interface FastEthernet1/1
description ### To KVP_FW2_P3 ###
duplex full
speed 100
interface Vlan1
ip address "ISP address"
ip flow ingress
ip flow egress
ip route-cache flow
interface Dialer1
ip address negotiated
ip mtu 1492
ip flow egress
encapsulation ppp
ip route-cache flow
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ip flow-cache timeout active 5
ip flow-export source Vlan1
ip flow-export version 5
ip flow-export destination 10.126.122.26 2055
But i still not see users addresses(each individual hosts will go though)
What and where i am configured wrong?
I also attached here the map network.
http://ns1.upanh.com/b4.s34.d3/c52113a71d9aee04f20a9c27efe575bc_51443091.network.jpg
Any help is appreciated,
Thanks & Best regards,
Seems you have NAT on a firewall between the hosts and the router. Because of this, the internal IP Addresses are hidden. This is the default behaviour from NetFlow when you have NAT - the internal hosts will be hidden by the NATed IP Address as your packets will carry the NAT IP and not the original IP Address as the source or destination.
Solution is to start traffic analytics on the firewall if your firewall supports flow export. In the scenario, one side will show the host IP and the other end will be the NAT IP.
Don Thomas Jacob
http://www.solarwinds.com/netflow-traffic-analyzer.aspx
NOTE: Please rate posts and close questions if you have found the answers helpful.
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
5 Replies 5
Trung Minh
Hello all,
Any one can help me this?
Best regards,
I cant access the image you uploaded. So, are you saying you cannot see the hosts in your network and see a NAT IP or do you not see traffic in a particular direction? Say, maybe IN or OUT?
Don Thomas Jacob
I can not see the hosts in my network
Example for show ip cache flow:
SrcIf         SrcIPaddress    DstIf         DstIPaddress    Pr SrcP DstP  Pkts
Vi1           58.87.42.22     Vl1*          113.160.131.250 06 0050 E55F     1
Vi1           217.160.130.148 Vl1*          113.160.131.250 06 1732 6166     1
Vi1           217.160.130.148 Vl1           113.160.131.250 06 1732 6166     1
Vi1           61.18.6.23      Vl1           113.160.131.250 11 612A 7052     1
Vl1           113.160.131.250 Di1*          58.87.43.34     06 CB56 159A     2
Vl1           113.160.131.250 Di1           58.87.43.34     06 CB56 159A     2
Vi1           61.18.6.23      Vl1*          113.160.131.250 11 612A 7052     1
Vi1           49.143.75.11    Vl1*          113.160.131.250 11 CCE3 C052     1
Vi1           49.143.75.11    Vl1           113.160.131.250 11 CCE3 C052     1
Vl1           113.160.131.250 Di1*          208.91.112.52   11 0D1E 0035     2
Vl1           113.160.131.250 Di1           208.91.112.52   11 0D1E 0035     2
Vi1           58.87.42.22     Vl1*          113.160.131.250 06 0050 C6D5     7
Vi1           58.87.42.22     Vl1*          113.160.131.250 06 0050 96D6     3
Vi1           58.87.42.22     Vl1           113.160.131.250 06 0050 96D6     3
Vi1           58.87.42.22     Vl1           113.160.131.250 06 0050 C6D5     7
It seems all ISP addresses.
I also attached a picture here.
Any help would be appreciated,
Best regards,
Does this router perform any type of NAT or does that occur on an attached firewall? It looks like the net flow information being pulled would be correct if you where looking at un-NAT traffic from the Internet.
Don Thomas Jacob
