Netflow on Sup7 no export of output
comicro
have a 4506-E with SuP7 and configured following:
flow exporter sv151
destination 10.139.40.98
transport udp 9996
# export-protocol netflow-v5
flow monitor m1
record r1
exporter sv151
cache timeout inactive 30
cache timeout active 60
cache entries 1000
flow record r1
match ipv4 source address
collect ipv4 protocol
collect ipv4 destination address
collect transport source-port
collect transport destination-port
collect interface input
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
interface GigabitEthernet3/37
description *** Swisscom IPSS ***
switchport access vlan 15
switchport mode access
ip flow monitor m1 input
ip flow monitor m1 output        ->  % Flow Monitor: 'm1' could not be added to interface due to invalid sub-traffic type: 0
no logging event link-status
no snmp trap link-status
spanning-tree portfast
Can export the input traffic of the interface or vlan but not the output, get the above error messages?
Some one an idea for solution?
cowetacoit
I too have a Sup7-E. This statement is straight out of the config guide..
"The configuration of the flow exporter does not support the option output features."
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/3.1.1SG/configuration/guide/fnf.html
I've also been working with TAC trying to get FnF configured correctly on the interfaces. Not sure if you are aware or now but there is no support for SVIs and probably won't be. Only physical interfaces like trunks and L3 ports. This is a config example for a trunk.
interface GigabitEthernet2/1
switchport trunk allowed vlan 35,50,80,90
switchport mode trunk
auto qos voip trust
service-policy input AutoQos-VoIP-Input-Cos-Policy
service-policy output AutoQos-VoIP-Output-Policy
vlan-range 35,50,80
  ip flow monitor NETFLOW_MONITOR input
end
