NetIPmanager Problem
harisapkota123
Level 2
Level 2
Dear all,
I configured SNMP on all the routers located in my network, I checked the configuration properly but it doesn't have problem, All the routers are showing the configurations via this software(Cisco NetIPmanager with license) , like CPU utilization, Platform, Capabilities etc,
But one of my router is not showing some parameters seen in this attachment, Could you Please
help me to sort out this problem?
Thx very much
bansell
Hi Hari
I notice that this is reflecting capabilities as HOST.  Go on the Devices tab and right click on the device > Properties to make sure that the credentials there match what is configured on the device.  If it is, right click on device and choose Device Management > Rediscover and hopefully the capabilities will be updated to reflect better what the device can actually do after that.
Hopefully helps
Billie
