network alert tool
flopez
Level 4
Level 4
does anyone know of a software that can notify me if one of my T1s links is down? I have two T1s from two different providers going to the same remote site and want to be able to be alerted when one of the links goes down.
And, I don't need anything fancy or expensive. Thanks in advance.
Julio,
5 Replies 5
dudeoflife1
Community Member
Do you ONLY want to monitor those links? Or, would it be helpful to monitor other things as well?
I've been using Nagios for my network monitor for some time now. I initially set it up just to monitor my networking devices but I quickly added much much more. It is a bit overkill just for monitoring a network interface, but I couldn't imagine life without it.
http://www.nagios.org/
Well, I really only want to monitor two T1s that I have. I'll take a look at the website, is it expensive? Do they charge you by number of devices?
is there something for the Windows OS?
Thanks, these links are awesome!
