Network Analysis Module (NAM-1) Software Upgrade
Dominic Wilkinson
Community Member
Hopefully this should be are really quick question to answer. After doing some research on the Cisco website, I'm lead to believe that I should be able to upgrade my WS-SVC-NAM-1 module to the version 5.0 of software. I have tried this several times on a couple of modules and it always fails.
I've searched numerous documents and can't find any caveats about the minimum spec for version 5.0
Here is the spec. from one of my NAMs:
Network Analysis Module                WS-SVC-NAM-1
Hardware: 1.0  Firmware: 7.2(1)  Software: 3.6(1b)
NAM application image version: 3.6(1b-Patch2)
Maintenance image version: 2.1(3)
BIOS Version: 4.0-Rel 6.0.4
PID: WS-SVC-NAM-1
Memory size: 512MB
Disk size: 20GB
Installed patches:
Thu Feb 16 10:35:49 2012 Patch: nam-app-patch.3-6-1b-1-1 Description: Patch 1 for NAM release 3.6(1b)
Thu Feb 16 10:37:00 2012 Patch: nam-app-patch.3-6-1b-2-0 Description: Patch 2 for NAM release 3.6(1b)
Should I be able to upgrade this NAM to version 5.0? If not, what are the minimum spec. caveats?
Dom
Dominic Wilkinson
Community Member
It looks like I need to upgrade my BIOS and I need go to
BIOS Version: 4.0-Rel 6.0.9
So where can I download B01MQ009.ROM from? I've checked on the download centre, but it's not listed anywhere that I can find.
I've already upgraded my Maintenance Image to Version 2.1(5).
So the only missing piece now is the BIOS upgrade. Can someone point me to where I can download this from?
Dom
Dominic,
The BIOS image is bundled with the NAM maintenance  image.  You said you upgraded the maintenance image to 2.1(5), What do you see when  issueing the show version?
Phil.
Hi Phil,
Thanks for your response. It would appear that the 6.0.9 isn't bundled with the Maintenance Image:
#show version
Maintenance image version: 2.1(5)
mp.2-1-5.bin : Tue Nov 11 20:29:43 GMT 2008 : integ@kplus-build-lx.cisco.com
Line Card Number :WS-SVC-NAM-1
Number of Pentium-class Processors :       2
BIOS Vendor: Phoenix Technologies Ltd.
Total available memory: 502 MB
Size of compact flash: 61 MB
Size of hard disk: 19077 MB
The BIOS version is still showing 6.0.4
As an aside when we carry out the upgrade to either version 4.0 or 5.0, the upgrade appears to be successful, but the NAM will just not stay online. Here is snip from the 6500 log:
May 31 12:27:10.590 utc: %SNMP-5-MODULETRAP: Module 3 [Up] Trap
May 31 12:27:10.490 utc: %OIR-SP-6-INSCARD: Card inserted in slot 3, interfaces are now online
May 31 12:28:02.766 utc: %SNMP-5-MODULETRAP: Module 3 [Down] Trap
May 31 12:28:02.742 utc: %OIR-SP-3-PWRCYCLE: Card in module 3, is being power-cycled 'off (Module not responding to Keep Alive polling)'
May 31 12:28:02.842 utc: %C6KPWR-SP-4-DISABLED: power to module in slot 3 set off (Module not responding to Keep Alive polling)
May 31 12:30:46.241 utc: %DIAG-SP-6-RUN_MINIMUM: Module 3: Running Minimal Diagnostics...
May 31 12:30:47.013 utc: %DIAG-SP-6-DIAG_OK: Module 3: Passed Online Diagnostics
May 31 12:30:47.487 utc: %SNMP-5-MODULETRAP: Module 3 [Up] Trap
May 31 12:30:47.498 utc: %OIR-SP-6-INSCARD: Card inserted in slot 3, interfaces are now online
May 31 12:31:38.691 utc: %SNMP-5-MODULETRAP: Module 3 [Down] Trap
May 31 12:31:38.667 utc: %OIR-SP-3-PWRCYCLE: Card in module 3, is being power-cycled 'off (Module not responding to Keep Alive polling)'
May 31 12:31:38.739 utc: %C6KPWR-SP-4-DISABLED: power to module in slot 3 set off (Module not responding to Keep Alive polling)
May 31 12:34:22.807 utc: %DIAG-SP-6-RUN_MINIMUM: Module 3: Running Minimal Diagnostics...
May 31 12:34:23.584 utc: %DIAG-SP-6-DIAG_OK: Module 3: Passed Online Diagnostics
May 31 12:34:23.984 utc: %SNMP-5-MODULETRAP: Module 3 [Up] Trap
May 31 12:34:23.984 utc: %OIR-SP-6-INSCARD: Card inserted in slot 3, interfaces are now online
May 31 12:46:23.464 utc: %NAM-3-NO_RESP: Module 3 is not responding
Dom
Finally found the information in the release notes! What a doozy!
http://www.cisco.com/en/US/docs/net_mgmt/network_analysis_module_software/5.0/release/notes/nam50note.html#wp43172
All sorted now! Upgrade successful.
Does anyone know the specification of the memory? I think Cisco are having a bit of a laugh at pricing a 2Gb SIMM at $2500!!! is it gold plated or something?
