Network Assistant and outgoing http proxy
petersamek
Is it possible to set an outgoing HTTP proxy for Network Assistant 2? Our network is behind a firewall and otherwise I cannot download any new updates.
Peter
irisrios
Level 6
Level 6
If CNA is behind firewall, you will not be able to download updates from cisco.com. There is no proxy server configuration yet available in CNA.
irisrios
Level 6
Level 6
aazim
CNA 3.0 now supports this functionality, however you first need to upgrade to CNA 3.0 and then from then onwards you will be able to get the upgrades through HTTP proxy.
Ajang
