Network error Using ACL in VTY conection
grzegorzkuras
Community Member
Helo I have  SW c3650. I've configured SSH, RSA Key and line VTY. AAA new model is already done.
Before I put ACL in VTY line I could reach my switch via ssh but when i put ACL i have network error.
i have create :
group object MGMT_GROUP
range x.x.x.x x.x.x.x - ip adresses of managament IP
next
I create ACL
ip access-list extended MGMT
permit tcp object-group MGMT_GROUP any eq 22 log-input
deny tcp any any range 0 65535 log-input
deny ip any any log-input
In VTY 0 4
access-class MGMT in
And my access via ssh is not working... when i put....no access-class MGMT I can connect my switch via ssh
Pease any sugestions ?
5 Replies 5
Pawan Raut
Level 10
Level 10
I see the example where extended ACL dont work as expected on line vty. I would suggest to have standard access list and just allow ssh.
access-list 11 permit x.x.x.x x.x.x.x
line vty 0 4
transport input ssh
access-class 11 in
Please rate for useful post
I've tried standard access list, such as group object maped to named acl and it doesnt work.
Object-group doesn't support in in standard ACLs, you can add host or network subnet in standard ACL to filter VTY access, try following config example.
ip access-list standard VTY_ALLOW
 permit 10.1.1.1
 permit 10.2.1.0 0.0.0.127
line vty 0 15
 transport input ssh
 access-class VTY_ALLOW in
-Muhammad Zahid
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
I have tried standard acl and it doesnt work..... moreover my config works in Packet Tracer ...
What's the issue you are facing? is it blocking legitimate connection or not blocking any ssh request at all ?
Verify either any traffic hitting to your acl "show access-list VTY_ACL"
