network health check and configuration advise
jfeo
I need to do this with a network with 200 router and switches. Does anybody have suggestion on how to approach this with software?
thanks
Leo Laohoo
Sorry, can you please be more descriptive about what you are trying to do?
I need to scan a network that has around 200 switches and routers. I also need to come up with recommendations and network visio diagram.
I was looking for suggestions on what software "snmp" that would be best for this and maybe cisco has something that I could use..
t
thank you
The Cisco product for this would be Cisco Prime LMS which is provided with purchases of Cisco Prime infrastructure. If you're brand new to network management though I wouldn't recommend taking on its deployment and configuration on your own as it is a pretty complex product and requires its own dedicated server.
Marvin Rhoads
Please have a look at the response I gave to a similar thread here.
Hopefully it will help you out.
