Network help needed
paulwhite
Community Member
  • Advanced Computers. is growing like crazy! Now, we need to put into place a more secure and faster connection between our headquarters and our satellite offices. The two locations are approximately one mile apart and are in a heavily populated area.
  • You can make assumptions as to what technologies, cabling, etc. are available.
  • In a Word document, you need to lay out, how you would connect these two facilities together using what you feel to be the best solution.
    • Include a budget, figures are going to be a range, which is understood
    • What technologies, hardware, software, cabling, etc. are you using to make the connection
    • Why is your choice the best choice (justify!)?
Deepak Kumar
If you asking me then I will take Internet connection at both locations and Will implement Site to Site IPSec connection.
IPSec site to Site connection and Cisco Router/FIrewall ASA or Meraki MX Device will install on both locations.
It will flexible, secure, and cheaper solutions compare to other solution as Dark fiber/MPLS connection.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Leo Laohoo
Paul,
You need to specify the word limit.
Most importantly, you will need to agree that no one here at the forum will be held responsible if your professor/instructor should/will give you a low score.
