Network Latency on intranet ?
kissimach
Network Latency?
How can I troubleshoot network latency on my ISP intranet or find what cause network latency on the
intranet?
Most of their routers and switch (are cisco).
The thing is that I have no clue at all on how to do it since there's so many many things that can cause network latency:
Applications
Switch, routers mis configured
VoIP etc.......
Help Please?
spremkumar
Level 9
Level 9
you can use few steps like benchmarking the latency in each segment of your intranet.
the best method is to do with normal icmp ping method and also keep a tab on the utilisation pattern in the intranet.
you can do this during peak and non peak hours during which you might see a difference in the load.
regds
