Network Performance Monitoring Software
ssmokinjoe
Hi, I am looking for some software that will allow me to monitor LAN/WAN traffic. We are in a Cisco switched network environment. The only thing that I have found so far is a product from Solarwinds. I would like to use something from Cisco if possible... Any ideas?
Thanks in advance,
-Joe
rmushtaq
Level 8
Level 8
You can use NAM module for this.
mfilser
Hi Joe.
IMHO, Cisco has not an own product to monitor LAN/WAN traffic (except NAM of course).
In the actual NMS-Solution, the Real-Time-Monitor (NetScout) is available, but it's an EOA-Product.
For myself, I'm using several tools, to monitor the traffic:
MRTG and JFFNMS (Freeware SNMP-Tools) are a little bit tricky to configure.
PRTG (www.paessler.com) is a nice Windowstool; very easy to use and configure (about 50 $)
TheGuard (www.realtech.de) is a full NMS-Software and includes a very good performance tool but not really cheap! (about 16k Euro)
eHealth (www.concord.com) is a pure monitoring tool for performance and availability, very good (I think, the best) but very expensive :-(
Hope this helps
Bye
Markus
Joe,
I think the Solarwinds Orion product is very good. We had Concord and I was able to buy a full Orion server for less then I was paying maintenace only with Concord.
I'd would recommend it to anyone.
BB
