Network Test
nasdaq123
Community Member
Hi All,
What would you recommend is the best tool to test the bandwidth and traffic on an MPLS network from one site to the Datacenter,  we have an issue with one of our supplier where their application seems to be the problem in transferring data traffic to the datacenter as i believe that it cannot work across multiple subnets (some routing deficiency).
They have now brought the application server to the local site and it works perfectly fine as it is on the same LAN as the application server and clients are now on the same subnet. They used a script using LAN Speed Test , i told them that this was an incorrect test to do as the LAN speed test is only used on P2P networks not on an MPLS WAN network,
they came back with the below excuse from their findings:
The test was setup in a way to simulate a file transfer through the network. The file size was set to 2.6MB which equals the size of an image. This file has been sent every 15sec to the server and we have measured the response time in msec which you can than convert to network speed. This test doesn’t measure the entire network performance/speed but the response time of a file transfer
Date
Write min
Write max
Read min
Read max
20-Jun-2017
60ms (333Mbit/s)
250ms (48Mbit/s)
60ms (333Mbit/s)
180ms (111Mbit/s)
21-Jun-2017
60ms (333Mbit/s)
450ms (44Mbit/s)
60ms (333Mbit/s)
190ms (105Mbit/s)
22-Jun-2017
60ms (333Mbit/s)
850ms (23Mbit/s)
60ms (333Mbit/s)
190ms (105Mbit/s)
23-Jun-2017
60ms (333Mbit/s)
430ms (46Mbit/s)
60ms (333Mbit/s)
160ms (125Mbit/s)
25-Jun-2017
60ms (333Mbit/s)
250ms (48Mbit/s)
60ms (333Mbit/s)
180ms (111Mbit/s)
26-Jun-2017
60ms (333Mbit/s)
860ms (23Mbit/s)
60ms (333Mbit/s)
270ms (74Mbit/s)
27-Jun-2017
60ms (333Mbit/s)
1070ms (18Mbit/s)
60ms (333Mbit/s)
180ms (111Mbit/s)
28-Jun-2017
100ms (200Mbit/s)
110ms (181Mbit/s)
70ms (285Mbit/s)
100ms (111Mbit/s)
29-Jun-2017
60ms (333Mbit/s)
990ms (20Mbit/s)
60ms (333Mbit/s)
160ms (125Mbit/s)
30-Jun-2017
60ms (333Mbit/s)
850ms (23Mbit/s)
60ms (333Mbit/s)
170ms (117Mbit/s)
01-Jul-2017
60ms (333Mbit/s)
440ms (45Mbit/s)
60ms (333Mbit/s)
150ms (133Mbit/s)
As you can see above the min response time was 60ms (read/write). Max peaks as above.
Overall the network operated within 70-90ms response time (read/write) with the exception 27-28 June and 01 Jul (afternoon). During this time the response time was significantly lower than usual (> 110ms).
21-Jun                 highest network performance at ~ 8am-10am
22-Jun                 highest network performance at ~ 2am-10am
27-Jun                 from 8am –
28-Jun                 to 11pm low network performance
01-Jul                  from 2pm on low network performance
Supplier recommendation for the network speed is 1 Gbit/s. At no time the  network achieved this performance. Typically it is working on a max 30% level of the recommended network speed.
Our Latency at site to the Datacenter is 3ms, how do we disprove this inaccurate test? Any Network Tool which can use i.e Iperf
Mark Malone
Iperf is a good test I have used it few times to make sure ISP is providing the full bw
https://www.sd-wan-experts.com/blog/iperf-bandwidth-testing/
ryansmith22014
Community Member
I suggest to test your network with CableIQ Qualification Tester provided by Fluke Networks.
CableIQ qualification tester is the first cabling bandwidth tester for network technicians.
