Prime 3.0 Compliance Input Rule Multiple Values
Hi all,
Does anyone know how a Rule Input with multiple values can be used?
For example I want to check if a specific SNMP trap source interface is configured (snmp-server trap-source Vlan10)
In our network this could be Loopback0 or Vlan10. If I cretae an Input Rule:
Title: Interfaces
Data Type: String
Accept Multiple Values
Scope: Execution
How can I check my configuration agains the values in the Rule Input?
I tried it with two conditions:
1: snmp-server trap-source (.*)
2:  <1.1> matches <_Interfaces>
But that didn't do it:
Violation: Configuration "Loopback10 matches [Vlan10, Loopback0]"
joshelton
I know this is a very old thread. But did you ever find a solution? I am trying to specify some interfaces to exclude from a check, and cannot find a proper syntax to make it work.
However, I am using the same logic you are with <1.1> matches <_Interfaces>
No, unfortunately not...
