Networking Advice
I would like to get someone’s opinion on the following changes I would like to make?
  • Am I going in the right direction?
  • Is this the correct direction
  • What would you do?
Just some Facts:
The current system is a mixture of old brocade and cisco switches and I would like to replace all with Meraki switches. And setup VLANs, place DHCP on the network and the company has 1 location with approx. 175 users, 250 devices, and 85 servers mostly virtualized. All running on 3 VLANs.
I would like to get some feedback on the following changes I want to make during the
Network cutover:
  • Would like to change over the Main network subnet from 192.168.1.0/24 to 192.168.10.0/24 Change from 1.0 network to 10.0 network
  • change or move Server, Printers, and other equipment to their respective VLANs to simplify network traffic, this can be moved at another Time, not during the cutover
  • Separate Desktop phones and computers to their own network ports to increase network port speed to the users’ devices (Currently all laptops and desktops are connected through the ShoreTel phone, which only allows the user to get 100MB network connection), this would increase user network connection to 1GB connection.
  • Move the wireless to its own VLAN and separate the WIFI networks, Main and GuestMove the building lighting controls to its own VLAN to separate it from our main network
  • Move the DHCP Service for each VLAN to the Network to improve network speed and offload this service from the Windows server. This will ensure if the Domain controller was ever down users could always connect to the network shares with cached user credentials and still be able to get to network shares and printers.
  •  If the Server DHCP was ever down users could always connect to the network shares with cached user credentials and still be able to get to network shares and printers.
These also can be moved or separated at another time, just wanted to get some feedback on these items
balaji.bandi
This required proper design guidance to understand the requirement to make the necessary design. You also need some FW in place to protect a network, you have not given that information.
If you have your own understanding of your requirement high level all look good your approach, but I look at some Cisco Catalyst switches here(until you going with full Meraki solution like MX controller, MR AP ? Meraki Switches).
Look at Campus Lan design :
https://www.cisco.com/c/en/us/td/docs/solutions/CVD/Campus/cisco-campus-lan-wlan-design-guide.html
If you Looking Meraki :
https://documentation.meraki.com/Architectures_and_Best_Practices
In both cases, why not plan high availability, 2 Servers in each service, once the user DHCP lease time expired he can not get any more IP addresses if the DHCP Server is not available, same case DNS Server resolution.
BB
