Networking issue
Hello sir,
I have made a topology:
Router(Router's Static IP 192.168.1.2) DHCP enabled(192.168.1.3 to 192.168.1.150) -> L2 Switch(192.168.1.1) -> PC.
Now issue is that sometimes signal drops on user end.
Can anyone suggest me if any change requires in IP configuration of router or switch?
I have attached network diagram also.
7 Replies 7
luis_cordova
Hi @yogenderrohilla2408 ,
Could you tell us what kind of tests you are doing?
Maybe sharing some diagram of your network could be useful too.
Sometimes internet network drops on user end.
I just want to know that, is there any need to change ip configuration on router or switch?
I have attached network diagram..
balaji.bandi
Signal Drop which point ( can you define what kind of signal Drop here )
You lost network or intermittent from Pc ? to Internet ?
in that time have you checked from router you able to reach internet ?
BB
Sometimes internet network gets down on user end.
I just want to know that, is there any need to change ip configuration on switch or router?
Many reasons, why it dropped.
1.May be internet side
2. may be router side
3. may be Switch side
4. may be user side.
This required and need to diagnosis the problem in each level of network. that is the reason NMS take advantage here to monitor things.
BB
Have you considered maybe changing the subnet? Instead of using 192 maybe use something else in your IP settings page
Please remember to rate useful posts, by clicking on the stars below.
Leo Laohoo
Please ask your instructor/professor for guidance.
