Networking Issues
SD488
I have been having a few issues with a network I need to set up. I have been trying to ressolve these for a few days now and cant seem to see the wood from the trees.
The issues i am having are as follows:
I dont think the 2 routers are connected properly as the networks on router 2 are unable to reach networks on router 1. Destination Host Unreachable when I try to ping one.
I am also having issues with emails which i am getting the error of SMTP Authentication Failure which I assume this is due to the routers not being properly configured and able to communicate with each other.
I was trying to send a test email from TS 1  to M 1.
Where am I going wrong? What am I missing?
My Project: https://easyupload.io/vx66fr
Thanks in advance
5 Replies 5
You can share file over here. You just need to zip.
Your router have no routing. I enable RIP on it. Take a look on this file and see it works now. I did not test email specificaly.
Keep in mind that if you are using name to send email, looks like your DNS server is not configured.
You need to add entries there like:
myemail.com  10.0.0.1 (example)
So that the machine can resolve name to Ip address in order for send email.
SD488
Thank you,
I have seen what you have done with enabling RIP. I have got a step further with emails being able to be sent but unable to be recieved. I am getting a POP3 error message now.
Teste now
SD488
I actually managed to fix it after i posted, but thank you very much for your help. Much appreciated.
You´re welcome.
