newbie: cisco static routing %Inconsistent Address and Mask
anyone1
when you adding static routes, you need to specify 'network address' and not the host IP unless you are specify mask as /32. try specifying full network address. for ex,.
ip route 192.168.12.128 255.255.255.224 192.168.12.161  - on surray router. and same way in other router.
also link between 2 routers need to be in same subnet. as per diagram, its in 2 different subnets which will not work.
rate and mark as answer if this solved your issue
Good luck
KB
it still did not worked
Seb Rupik
Hi there,
There is a some discrepencies between your diagram and the table of configuration. For reference, PC1 should have the following config:
IP: 192.168.12.158
mask: 255.255.255.224
DGW: 192.168.12.129
Remove whatever static routes you have currrently configured, and add this config:
!! calgary-router
ip route 192.168.12.0 255.255.255.128 192.168.12.162
!! surrey-router
int fa0/1
  ip address 192.168.12.162 255.255.255.252
cheers,
Seb.
post the zipped Packet Tracer project (.pkt) file...
