Nexus 5500 or 6000 support for OSPFv3 auth
from88
Level 4
Level 4
I've started configuring OSPFv3 for DC network and started to see that there's no feature imp command, which would enable the authentification for OSPFv3. Do i'm missing here something ?
Because on Nexus 9Ks i see the feature imp command and i can enable auth for OSPFv3 successfully there. Digged through some manuals - no information that 5k or 6k series are missing that.
Maybe you know - do OSPv3 auth is supported on Nexus 5k or 6k series at all ? Thanks
balaji.bandi
hey,
i've seen that documentations, and actually they dont say or show as example that auth for n5k is available:
N5K-C5548UP system: version 7.3(8)N1(1)
SwitchA(config)# feature i?
  interface-vlan  Enable/Disable interface vlan
  isis            Enable/Disable IS-IS Unicast Routing Protocol (IS-IS)
  itd             Enable/Disable ITD
While on n9k imp is available:
COREA(config)# feature i?
  icam            Enable/Disable icam
  imp             Enable/Disable IMP
Licensing Requirements for OSPFv3
The following table shows the licensing requirements for this feature:
Product
License Requirement
Cisco NX-OS
OSPFv3 requires an Enterprise Services license. For a complete explanation of the Cisco NX-OS licensing scheme and how to obtain and apply licenses, see the Cisco NX-OS Licensing Guide.
BB
Yes, thanks, but according Cisco NX-OS Licensing Guide its enough to have LAN_BASE_SERVICES_PKG license.
Anyhow, i've Enterprese services license also:
SwitchA# show license usage
Feature                      Ins  Lic   Status Expiry Date Comments
                                 Count
FCOE_NPV_PKG                  No    -   Unused             -
FM_SERVER_PKG                 No    -   Unused             -
ENTERPRISE_PKG                No    -   Unused             -
FC_FEATURES_PKG               No    -   Unused             -
VMFEX_FEATURE_PKG             Yes   -   Unused never       -
ENHANCED_LAYER2_PKG           No    -   Unused             -
NETWORK_SERVICES_PKG          No    -   Unused             -
LAN_BASE_SERVICES_PKG         Yes   -   In use never       -
LAN_ENTERPRISE_SERVICES_PKG   Yes   -   In use never       -
SwitchA# show license usage LAN_BASE_SERVICES_PKG
Application
pim
btcm
ospf
ospfv3
So, i still think nexus 5k and 6k doesnt have authentification for OSPFv3.
