Nexus switch not asking enable password,
Robin.Wang2020
we have a Nexus C93180YC-FX Switch, when I ssh to it, I directly get Privileged EXEC mode #, didn't see User EXEC mode ">".
there is no AAA, and I enabled secret.
who can help me with this issue ?
thanks.
6 Replies 6
balaji.bandi
check you have VTY Line config - "privilege level 15"  or post the config to understand.,
BB
Robin.Wang2020
thank you for your reply, but there is no option under line vty for privilege 15.
post the configuration to understand what is wrong?
or check the reference :
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/command/reference/security/n5k-sec-cr/n5k-sec_cmds_e.html
BB
thanks.
Robin.Wang2020
Here are related configuration please take a look on it. thanks.
show run
!Command: show running-config
!Running configuration last done at: Sun May 16 18:33:05 2021
!Time: Tue May 18 18:02:39 2021
version 9.3(3) Bios:version 05.42
install feature-set mpls
vdc G-1_5 id 1
  allow feature-set mpls
  limit-resource vlan minimum 16 maximum 4094
  limit-resource vrf minimum 2 maximum 4096
  limit-resource port-channel minimum 0 maximum 511
  limit-resource u4route-mem minimum 248 maximum 248
  limit-resource u6route-mem minimum 96 maximum 96
  limit-resource m4route-mem minimum 58 maximum 58
  limit-resource m6route-mem minimum 8 maximum 8
feature-set mpls
feature privilege
feature vrrp
cfs eth distribute
feature bgp
feature mpls l3vpn
feature interface-vlan
feature lacp
feature vpc
feature lldp
feature vtp
feature nat
username neess password 5 xxxxx  role neess
username netadmin passphrase  lifetime 99999 warntime 14 gracetime 3
ssh key rsa 2048
enable secret 5 xxxxxxx
ip domain-lookup
crypto key generate rsa label GRPD-MDF_N9K-C93180-1_5 modulus 2048
system default switchport
copp profile strict
snmp-server user admin ne auth md5 0xce956d8801c9f424dd923c29893eaf39 priv 0xce956d8801c9f424dd923
c29893eaf39 localizedkey
snmp-server user ns ne auth md5 0xce956d8801c9f424dd923c29893eaf39 priv 0xce956d8801c9f424dd
923c29893eaf39 localizedkey
rmon event 1 description FATAL(1) owner PMON@FATAL
rmon event 2 description CRITICAL(2) owner PMON@CRITICAL
rmon event 3 description ERROR(3) owner PMON@ERROR
rmon event 4 description WARNING(4) owner PMON@WARNING
rmon event 5 description INFORMATION(5) owner PMON@INFO
line console
line vty
boot nxos bootflash:/nxos.9.3.3.bin
no system default switchport shutdown
who can help here?
