Nexus9000 still not supported on Prime Infrastructure 3.9., WHY?
David Ritter
Level 4
Level 4
Any one know why the Nexus 9000 is (still) not supported on the Pi3.9, or how to fix the issue?
I have 4 of them..
Device Information:​‌
- Device Type: NX-OS​‌
- Model: Nexus9000​‌
- Version: 7.0(3)I7(5)​‌
- Serial Number: FDO2239xxx
tcl389/admin# show version
Cisco Application Deployment Engine OS Release: 4.1
ADE-OS Build Version: 4.1.0.001
ADE-OS System Architecture: x86_64
Copyright (c) 2009-2021 by Cisco Systems, Inc.
All rights reserved.
Hostname: tcl389
Version information of installed applications
Cisco Prime Infrastructure
Version : 3.9.0 [FIPS not Enabled]
Build : 3.9.0.0.219
Critical Fixes:
PI 3.9 OCT Oracle Patch ( 1.0.8 )
PI 3.9.1 Maintenance Release ( 1.0.21 )
PI 3.9.1 Security Update 01 ( 1.0.0 )
PI 3.9.1 Update 01 ( 1.0.0 )
Device Support:
Prime Infrastructure 3.9 Device Pack 1 ( 1.0 )
tcl389/admin#
2 Accepted Solutions
 According to the PI39-Supported-Devices-List, those Nexus should be supported. But, we can also see some Bugs related to this.
You need to have the Device Pack installed.
Cisco Nexus 9396PX Switch 1.3.6.1.4.1.9.12.3.1.3.1508 All Versions (NX-OS\(tm\)), IOS Y TFTP,SFTP, SCP FTP, TFTP, SFTP, SCP FTP, TFTP, SFTP, SCP No Yes Yes
Cisco Nexus 9396TX Switch 1.3.6.1.4.1.9.12.3.1.3.1509 All Versions (NX-OS\(tm\)), IOS Y TFTP,SFTP, SCP FTP, TFTP, SFTP, SCP FTP, TFTP, SFTP, SCP No Yes Yes
Cisco Nexus 93128TX Switch 1.3.6.1.4.1.9.12.3.1.3.1510 All Versions (NX-OS\(tm\)), IOS Y TFTP,SFTP, SCP FTP, TFTP, SFTP, SCP FTP, TFTP, SFTP, SCP No Yes Yes
Cisco Nexus 9504 Switch 1.3.6.1.4.1.9.12.3.1.3.1507 All Versions (NX-OS\(tm\)), IOS Y TFTP,SFTP, SCP FTP, TFTP, SFTP, SCP FTP, TFTP, SFTP, SCP No Yes Yes
Cisco Nexus 9516 Switch 1.3.6.1.4.1.9.12.3.1.3.1506 All Versions (NX-OS\(tm\)), IOS Y TFTP,SFTP, SCP FTP, TFTP, SFTP, SCP FTP, TFTP, SFTP, SCP No Yes Yes
Cisco Nexus 7000 4-Slot Switch 1.3.6.1.4.1.9.12.3.1.3.1147 All Versions (NX-OS\(tm\)), IOS Y TFTP,SFTP, SCP FTP, TFTP, SFTP, SCP FTP, TFTP, SFTP, SCP No Yes Yes
Cisco Nexus 5010 Switch 1.3.6.1.4.1.9.12.3.1.3.798 All Versions (NX-OS\(tm\)), IOS Y TFTP,SFTP, SCP FTP, TFTP, SFTP, SCP FTP, TFTP, SFTP, SCP No Yes Yes
marce1000
 - For an overview of compatibility info's go here :  https://www.cisco.com/c/en/us/support/cloud-systems-management/prime-infrastructure/products-device-support-tables-list.html , check if there is improvement in the latest Prime version.
 M.
Ah Thank you ..
But I do have the current Device Pack installed.
they appear to be
cisco Nexus9000 C93240YC-FX2 Chassis
Intel(R) Xeon(R) CPU D-1526 @ 1.80GHz with 24571604 kB of memory.
Processor Board ID FDO22382KAQ
which are not included in the list.
Thank you
marce1000
 M.
hihi  and still not supported in 3.10
only nexus 93xx and 95xx, no 90xx's
oh well no big deal..
