no auto summary BGP
Mukesh
Hi all
I can't issue the following command.
no auto summary command under router bgp 65000
conf t
router bgp 65000
no auto summary
it goes under address-family ipv4 will that be an issue?
address-family ipv4
no auto summary
Harold Ritter
Hi @Mukesh  ,
"no auto-summary" has been the default behavior for BGP for years now, so no need to configure it.
balaji.bandi
depends on use case :
auto-summary (BGP)
To configure automatic summarization of subnet routes into network-level routes, use the auto-summary command in address family or router configuration mode. To disable automatic summarization and send subprefix routing information across classful network boundaries, use the no form of this command.
auto-summary
no auto-summary
Since  BGP can support multi-protocol you can use address-family ipv4 (unicast or Multicast)
BB
Harold Ritter
Hi @Mukesh  ,
M02@rt37
Hello @Mukesh ,
Auto-summary behavior has changed across Cisco IOS software releases. Initially, auto-summary was enabled by default. However, with Cisco bug ID CSCdu81680 this behavior has changed. In the latest Cisco IOS, auto-summary is disabled by default.
Best regards
