No Nexus switches listed in Cisco ISE (v2.4) network component compatibility matrix
dam0c0nr0y
The "Cisco Identity Services Engine (ISE) Network Component Compatibility" document (Release 2.4) here does not have any Nexus devices listed.
Can anyone on the community confirm if:
  1. Nexus switches are compatible / incompatible with ISE running v2.4?
  2. There are any known interoperability (or incompatibility) issues between Cisco ISE and Nexus 9000 series switches specifically?
Any light which can be shed on the subject much appreciated.
Damian
0 Replies 0
