No switch health data web console Cisco 3560.
Gypsy Dave
Hi all,
I've enabled the http server option on my 3560 switch but when I logon to the web console I don't have any data in the "switch health" other than the temperature.
Under Monitor, Trends no data either.
Do I need to enable anything else to receive this data?
balaji.bandi
can you post some screenshot to understand the issue along with config.,
BB
Thanks for the reply:
sw-servers#show running-config
Building configuration...
Current configuration : 1605 bytes
! Last configuration change at 13:35:33 UTC Fri Mar 13 2020
! NVRAM config last updated at 13:25:00 UTC Fri Mar 13 2020 by xxxxxx
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname sw-servers
enable secret 5 xxxxxxxxxxxxxxxxxxx
username xxxxx privilege 15 secret 5 xxxxxxxxxxxxxxxxxxxxxxxxx
no aaa new-model
clock timezone UTC 1
clock summer-time UTC recurring last Sun Mar 2:00 last Sun Oct 3:00
system mtu routing 1500
ip subnet-zero
cluster enable SanMiguel01 0
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
 description AppleTV
 switchport mode access
interface FastEthernet0/2
 description SamsungTV
interface FastEthernet0/3
 description SteamLink
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface GigabitEthernet0/1
 description LINK-FG-LAN
interface Vlan1
 ip address x.x.x.x x.x.x.x
ip default-gateway x.x.x.x
ip classless
ip http server
control-plane
banner motd ^C
Unauthorised access is prohibited!!!!
^C
line con 0
 exec-timeout 30 0
 password 7 xxxxxxxxxxxxx
 logging synchronous
 login
line vty 0 4
 logging synchronous
 login
 length 0
line vty 5 15
 login
end
