No syslogs in Cisco Prime Infrastructure 2.2 from Cisco WLC (AirOS 8.0.115)???
Hi all. Сonfigured on WLC Syslog Server IP Address (ip address Cisco Prime Infrastructure), Syslog Level - Debugging, Syslog Facility - Local Use 0. And in Monitor > Alarms and Events > Syslogs (Cisco Prime Infrastructure) no data available from Cisco WLC. Thus WLC in the CPI 2.2 with access points visible, but no syslogs. How to configure WLC and CPI 2.2 for collect syslogs???
Charles Hill
Hey Sergey,
It looks like you are hitting bug CSCut76763.
PI2.2 does not show Syslogs sent from WLC running release 7.3 or later
CSCut76763
Workaround:
Downgrade WLC to 7.0 or use alternative Syslog server to receive Syslogs sent from WLC.
Hope this helps,
Please rate helpful posts.
Thanks.
Charles Hill
Hey Sergey,
CSCut76763
Workaround:
Hope this helps,
Thanks.
