No wired clients Prime 2.1
Jamie Hancock
Hi all,
Hopefully this will be relatively simple. I have Cisco Prime 2.1. I have recently added a number of switches which are happily functioning. The problem I have is the wired client count is 0.
Is there something I need to enable?
Jamie.
AFROJ AHMAD
Hi Jamie,
Prime infrastructure uses MIB to collect the Mac address of the clients; this MIB collects
the information per vlan.
So we need to configure SNMP context for all vlans to view the wired client.
Try configure SNMP context on devices , then delete and re-add the device and check the issue.
For e.g:
snmp-server group gcobergroup v3 auth context vlan-1
snmp-server group gcobergroup v3 auth context vlan-71
Thanks-
Afroz
****Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
