Not able to add Dell switches to prime 3.1
Jas1066
Hello All,
Trying to add dell switches to prime 3.1, the switches are S6000-ON want to monitor the utilization of one of the interface.
I have the MIB last one the list .zip
https://www.force10networks.com/CSPortal20/KnowledgeBase/Documentation.aspx
On prime
Monitor / Monitoring Tools / Monitoring Policies>
custom mib
upload mib
Maybe Dell MIB files not compatible with cisco prime?  as other Cisco MIBs work fine.
Thanks for any info
Hello Estimated,
I think Prime is adding support for specific devices in the new versions but like you said the hole support is for Cisco devices.
Please do not forget to rate or mark useful post. your rating motivates us to continue participating in the community.
Best Regards,
Diana Karolina Rojas
Estimated,
I think your switch is not supported by Prime, you can review the devices compatibles with you version here https://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/prime/infrastructure/3-1/supported/devices/PI31-Supported-Device-List.xlsx
Please do not forget to rate useful post.
Best Regards,
Thanks Diana for the reply.
Yes i don't see any Dell switches or any other non-Cisco.
Prime discovered all my dell switch with the SNMP string.  I can do a SNMPwalk via Prime, but will not gather any info from it via the PRIME GUI ie interface utilization/bandwidth.
So i am thinking maybe i wasting my time on Prime as we have a mixed vendor environment.
Thanks for any info
Hello Estimated,
Best Regards,
Hi Diana,
How about getting traps/syslogs from 3rd party devices Dell S4048/S6000 will this work on Prime?
