notify *tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF0F
Engineer-US
After adding this command:
snmp-server group TS v3 auth write v3View access 22
it show up like this:
snmp-server group TS v3 auth write v3View notify *tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF0F access 22
Any idea why this ((notify *tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF0F)) added to the command?
Thank you.
6 Replies 6
marce1000
             - You may get more info on that with : show snmp view
 M.
stack#sh snmp view
v3View iso - included nonvolatile active
v1default iso - included permanent active
v1default internet - included permanent active
v1default snmpUsmMIB - excluded permanent active
v1default snmpVacmMIB - excluded permanent active
v1default snmpCommunityMIB - excluded permanent active
v1default ciscoMgmt.252 - excluded permanent active
*tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF7F iso - included volatile active
*tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF7F iso.2.840.10036 - included volatile active
 - It may relate to snmp accessibility to a particular oid-tree (iso related) ; try this configuration command :
               snmp-server view notifyview iso excluded , then issue show snmp view again.
 M.
Hi Marce,
Thank you for your reply, see below the output after applying the command you recommended.
stack#sh run | i snmp-server
snmp-server view v3View iso included
snmp-server trap-source Loopback0
snmp-server source-interface informs Loopback0
snmp-server system-shutdown
snmp-server host 10.10.10.10 version 3 auth usrev3
stack#sh snmp view
notifyview iso - excluded nonvolatile active
*tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF0F iso - included volatile active
*tv.FFFFFFFF.FFFFFFFF.FFFFFFFF.FFFFFFFF0F iso.2.840.10036 - included volatile active
stack#
Any other ideas how to fix this issue please?
j.pattinson
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/snmp/command/nm-snmp-cr-book/nm-snmp-cr-s5.html
Configuring Notify Views
The notify-view option is available for two reasons:
  • If a group has a notify view that is set using SNMP, you may need to change the notify view.
  • The snmp-server host command may have been configured before the snmp-server group command. In this case, you must either reconfigure the snmp-server host command, or specify the appropriate notify view.
Specifying a notify view when configuring an SNMP group is not recommended, for the following reasons:
  • The snmp-server host command autogenerates a notify view for the user, and then adds it to the group associated with that user.
  • Modifying the group’s notify view will affect all users associated with that group.
Instead of specifying the notify view for a group as part of the snmp-server group command, use the following commands in the order specified:
  1. snmp-server user --Configures an SNMP user.
  2. snmp-server group --Configures an SNMP group, without adding a notify view .
  3. snmp-server host --Autogenerates the notify view by specifying the recipient of a trap operation.
