NTP Issue
Edgar Servin
I am needing a NTP Server in "Windows Server" in such a way to use the NTP in my infrastructure with cisco routers with authentication supports.
I'm testing with "NTP 4.X". The application works without authentication but I can not run with authentication required.
Someone has already gone through this need?
Help me please.
Edgar Servín
9 Replies 9
tkatsiaounis
Have you tried Meinberg NTP?? It essentially is linux ntp server for windows.
http://www.meinberg.de/english/sw/ntp.htm
Hi Tkatsiaounis,
Meinberg NTP 4.X is the software I am using.
Its documentation is not very understandable to me.
I can't make it work correctly with authentication.
I set up in my "Cisco router" with the command "ntp authenticate". The "NTP server" continues to operate but by entering the command: "show ntp asso detail" don't shows me the message "authenticated".
Do you have a sample configuration? Could you guide me in my setup, please?
Hi Leo,
The "Windows Server" uses the "SNTP / NTP" and does not work with Cisco IOS NTP.
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080a23d02.shtml
Regards.
Ok then.  It's either you let the routers go out to the net for an authoritative NTP source or you can purchase a "true" NTP server.
When I mean a "true" NTP server, it's not the kind which has to go out to the internet and to get an authoritative source.  I mean the ones with built-in GPS receivers.
I think it's very difficult to add a GPS for NTP on our infrastructure.
Although I think would be good.
I need an example of configuration of meinberg NTP.
Edgar
You don't need to install the NTP server inside the DC.  Find a cabinet that's closest to the ceiling and it'll do fine.  The servers normally come with a magnetic antenna.
Hi Leo,
We didn't planning an acquisition of a GPS for NTP.
Just for that I'm looking for the solution through the Meinberg NTP.
It is not necessary for our infrastructure a NTP server so specialized.
Only one that allows us to maintain uniform time in the network of PCs and routers, that provides NTP authentication.
Edgar
Hello, I was looking for a solution between many devices on my networks, finally I find a option, use a border router like a NTP Proxy.
I try many setting between MS Windows like a NTP Server over other devices no PCs, in my case don't work, but I try with a Router like NTP Server, perfect work.
Other good practice is send params over DHCP sending to the clients option 42.
Let the commands and screens:
NTP Server ~ Client on the Router:
ntp logging
ntp clock-period 17179973
ntp master
ntp update-calendar
ntp server 129.6.15.29 source FastEthernet1
ntp server 129.6.15.28 source FastEthernet0
Config NTP on DHCP Server:
ip dhcp pool LAN
   network 172.16.1.0 255.255.255.192
   update dns both
   domain-name example.ext
   default-router 172.16.1.1
   dns-server 172.16.1.58
   netbios-node-type b-node
   option 42 ip 172.16.1.1
   lease 0 0 5
   update arp
Analyzing DHCP behavior with Wireshark:
Set on MS Windows:
Depend of MS Windows behaviour, Windows Domain (atomically) Vs Workgroup (set in MS Clients IP or Router FQDN Master NTP)
Cheers!
