cisco PRIMER LMS 4.1 and NEXUS 7000
is the LMS 4.1 supports Nexus 7000 baundle ?
Vinod Arya
Cisco Prime LMS 4.1 support Nexus 7K and other Data Center Switches but for some features. following is the Summary :
The following features are supported:
  • Network Topology Layer 2 Services
  • User Tracking (Nexus 7K without FEX)
  • Fault Management
  • Inventory Collection (Nexus 7K, Nexus 5K with FEX)
  • Software Images Import from: Cisco.com, Device, File System, Network, URL
  • Upgrade Analysis from: Cisco.com, Repository
  • Software Image Import Connection Protocols: SNMP
  • Software Image Import Transfer Protocols: TFTP
  • Software Image Types for Distribution: System Software, Bootloader
  • Software Image Distribution Transfer Protocols: TFTP
  • Software Image Distribution Connection Protocols: SNMP
  • Configuration Deploy Protocols: TELNET, SSH
  • Configuration Fetch Protocols: TELNET, SSH
  • CiscoView
  • EW-2 [15.0(1)M2]
  • Non-Admin VDC ( Applicable only  for Nexus 7K devices)
The following features are not supported:
  • User Tracking (Nexus 1K, 4K, 5K and 7K with FEX), VLAN Management, VRF Lite, LANE Management
  • Configuration Deploy Protocols: HTTPS, SCP, TFTP, RCP
  • Configuration Fetch Protocols: HTTPS, SCP, TFTP, RCP
  • Software Distribution by: Advanced flow, Image, Remote Staging
  • Software Repository Synchronization
  • CiscoView -  [ 1.3.6.1.4.1.9.12.3.1.3.840, 1.3.6.1.4.1.9.12.3.1.3.903, 1.3.6.1.4.1.9.12.3.1.3.907, 1.3.6.1.4.1.9.12.3.1.3.930]
For more details check :
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.1/device_support/table/lms41sdt.html#Data Center Switches
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Vinod Arya
  • Fault Management
  • CiscoView
  • EW-2 [15.0(1)M2]
-Thanks
thanks for helping
