objects show up even when nothing plugged into port - EEM Script
Gerard Roy
Level 2
Level 2
After a reboot my cisco shows the objects it tracks as up even when nothing is plugged into the interface used to track the objects. I have an EEM script that reboots the router 1 time when it finds that 4 dial numbers it round robins thru are unavialable and this works. The problem is after the reboot it see's the objects as available and re-inserts the reboot script and when they finally show down as they should be the reboot hapens over and over. Any Ideas on how to get the router to not show the tracked objects up after a reboot if the interface is down?
Joe Clarke
As I said in the other thread, I suspect the "delay down" is causing the behavior you are seeing.
