OID for incoming/outgoing calls
bauerdp
I'm trying to find the OID to monitor the # of incoming/outgoing calls on a T1 module on a 2851 router. Is this possible?
Joe Clarke
What version and feature set of IOS are you running?
(C2800NM-ADVIPSERVICESK9-M), Version 12.4(3c)
You have the CISCO-CALL-HISTORY-MIB and the ciscoCallHistoryTable you can use to get details about incoming and outgoing calls. This is probably your best bet for getting historical call details.
While the MIB is supported, this particular object may not be, but you can try the cpmCallVolSuccISDNDigital object in the CISCO-POP-MGMT-MIB. This will give you the total number of digital incoming and outgoing calls.
For a list of call the MIBs supported in this image, see http://tools.cisco.com/ITDIT/MIBS/MainServlet?ReleaseSel=2102&PlatformSel=54&fsSel=19 .
