OID for Stack Utilization?
Chris Lindberg
Visitor
If I run the command "sh controller utilization | include Stack" on my 7 node Cat 3750 stack I get a % utilization for the stack ring.  I've poked around some, but cannot find any OID info for this statistic.  Has anyone else found such a thing?  Is it even in there?
Since the number is usually a 3 or 6 or such I can't really just do a search for the value without examining thousands of results from the SNMP walk...
Thanks!
Joe Clarke
No, not by default.  However, (depending on your IOS version) you could use the Embedded Automation Systems (EASy) Custom MIB package to install an EXPRESSION-MIB object to track this CLI output.  See http://www.cisco.com/en/US/prod/iosswrel/ps6537/ps6555/ps10777/eas_sol_downloads.html for the package download and documentation on how to install and use it.
