OID's keep changing
00uv4hyt1ZlDrrQyK5d6
Community Member
We have 2 IPsec tunnels created on Cisco 1111 8p router & we want to monitor the tunnels through our monitoring.
We have a predefined template available in our monitoring tool to monitor this service, but its not accurate. Hence did SNMP walk & found the OID of the service & configured it in monitoring , but we observed that OID keep changing.
Ex: Yesterday I did a snmp walk & found that the OID of VPN tunnel is OID=.1.3.6.1.4.1.9.9.171.1.2.3.1.7.58, Type=OctetString, Value=040.085.218.065 & to today again I did a snmp walk & it gave me a different OID.
Can someone suggest how can I efficiently monitor the VPN tunnels using OID ?
balaji.bandi
check this information may help you :
https://community.cisco.com/t5/networking-documents/how-can-i-monitor-vpn-tunnel-status-through-snmp/ta-p/3130785
BB
Peter Paluch
I am not sure if this suggestion helps but let's try: I suspect that the interface OIDs are changing everytime the tunnels are brought down and back up, or when they are internally recreated in IOS-XE. Can you try configuring snmp ifmib ifindex persist in your global configuration and see if that improves anything?
Best regards,
Peter
