10-13-2010 02:46 AM
Hi everyone,
I'm trying to monitor the NAT total active translations using SNMP polling.
When I issue command "show ip nat statistics", I could see the total active translations number at first line.(see attached file)
Is there any OID that I could use to get this value?
sh version
Cisco IOS Software, 3800 Software (C3845-ENTBASEK9-M), Version 12.4(25b), RELEAS
E SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 12-Aug-09 15:52 by prod_rel_team
any reply would be welcome.
10-14-2010 04:00 AM
To monitor NAT related information you can check CISCO-IETF-NAT-MIB. However, there is no oid to monitor the NAT total active translations.
As a workaround you could use CUSTOM-MIB eem script available at http://forums.cisco.com/eforum/servlet/EEM?page=eem&fn=script&scriptId=1741
10-19-2010 12:40 AM
Thanks for your sharing, but customer ask me to open a TAC to verify.
I will post the result from TAC then.
If we need to use EEM to solve this problem, it's a tough task to extract the value we want from the output lines.
Hope it's going to work as we thought.
02-10-2016 12:44 AM
Hello!
did you resolve you issue?
I found this:
sh conn count
oid .1.3.6.1.4.1.9.9.147.1.2.2.2.1.5.40.6
