Old Switches
vicorly
Good Evening;
A new client of mine has two, likely identical Cisco switches. I can’t tell their model number, but they are 48 port switches. I can only tell what their MAC addresses are, and they probably have default login info.
Can you please tell me what model the switches with these MAC addresses are?
6C:6C:D3:E2:F8:3C
6C:6C:D3:E2:FB:39
Victor
only we can tell is this MAC addresses reserved for cisco systems.
Good luck
KB
Hmmm.... I figured Cisco might have a database to match the MAC address with the actual device.
 - No they don't , they have a database using the serial number though : https://cway.cisco.com/sncheck/ , it will give you the model info(s) ,
 M.
post a picture of the switch(es). When you say 'old', it could be 3548XL switches...
