Router on a stick on packet tracer
achrafdotcisco
I have the following topology:
Every client on a VLAN can ping to the subinterfaces in the routers (Fortigate) but the clients can't ping each other between diffirent VLAN'S:
I use multiple VLAN's on each Switch example: on S3 vlan 50 Management and 60 IT:
Someone who can help me? Thanks a lot!
on the Fortigate, you have 'ip routing' disabled.
no ip cef
no ip routing
Enable 'ip routing':
Fortigate(config)#ip routing
9 Replies 9
balaji.bandi
what you see on the logs of fortigate, when the you ping PC to PC ?
First thing need to check :
End device have correct gateway and subnet
end device can ping their gateway
end device has any Firewall and it is disabled ?
From the router are you able to ping the end device IP address ?
if all tests and still not working post the below information for us to look into the issue.
Hope all the switches act as Layer 2 only ?
you have 2 Fortigate here in the diagram, how are they acting Active/Standby ?
BB
post the zipped Packet Tracer project (.pkt) file...
Here you are.
Thank you!
what are the device passwords ?
sorry i forgot it,
cisco and cisco123
no ip cef
no ip routing
Thank so much @Georg Pauwen !!!
easy fix...good luck with your project, and happy new year !
achrafdotcisco
Thank you for your help,
Yes every End device have correct gateway and subnet given by the right DHCP pool from the 1941 routers (named:fortigate)
Every end device can ping their gateway
There is no Firewall (Fortigates are only 1941 routers not fortigates)
From the router i am able to ping the end device IP address.
All the switches act as Layer 2 only (2960)
Like i said for the 2 Fortigate in the diagram its only the name but those are Cisco 1941 routers.
