output drops on port channel
tedauction
Hello, I notice on this port channel interface that total output drops are approx. 4 times greater than the total output traffic.
Does anyone know how this could be or I am misinterpreting it ?
Thank you kindly.
Port-channel2 is up, line protocol is up (connected)
MTU 1500 bytes, BW 4000000 Kbit/sec, DLY 10 usec,
Full-duplex, 1000Mb/s, link type is auto, media type is
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 4294939952
1017949081 packets output, 769486864270 bytes, 0 underruns
Also just noticed the same thing on a GigEthernet port i.e. the total output drops are greater than the packets output.
GigabitEthernet1/0/14 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 4c00.8289.590e (bia 4c00.8289.590e)
Description: "Kordia Multicast VLAN 4 (Satellite Backup)"
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 3d16h, output 3d16h, output hang never
Last clearing of "show interface" counters 2y13w
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 122515786
Queueing strategy: fifo
Output queue: 0/40 (size/max)
37726934063 packets input, 13282164821203 bytes, 0 no buffer
Received 3363232823 broadcasts (3135340999 multicasts)
0 watchdog, 3135340999 multicast, 0 pause input
78347464 packets output, 7607451631 bytes, 0 underruns
0 Replies 0
