Packages ASR(1.2) and SharedNetcofigIOSXR(1.0.1) for RME 4.1
aserov
I can not install package ASR(1.2) because it require SharedNetconfigIOSXR(1.0.1) but in Download area I found only SharedNetconfigIOSXR(1.0).
Is there any way to install it?
Gaganjeet Chug
Level 4
Level 4
Kindly go ahead and install the base package first SharedNetconfigIOSXR(1.0). and then check again if you are able to see the SharedNetconfigIOSXR(1.0.1) available for download.
Kindly share the screenshot too if having any issues.
Gaganjeet
My primary goal is to install latest ASR package, but when I try to install it I receive th next:
C:\psu_download>psucli -p rme -i -src c:/psu_download/rme ASR
Services might be restarted, as a result of install operation
Would you like to continue ? ( Press y or n )
y
Proceeding with install..
Loaded psu.properties..
INFO: Installing for rme
Locking the package repository...
got all packages Repository
Checking Dependencies...
WARNING: ASR(1.2):Consistency check failed for base package SharedNetconfigIOSXR
There are no Packages to be installed
Released the Lock...
No package(s) to install for Resource Manager Essentials
C:\psu_download>psucli -p rme -d -dst c:/psu_download/rme SharedNetconfigIOSXR
NMSROOT  = C:\Program Files\CSCOpx
directory specified :C:\psu_download\rme
Proxy Server is configured in CiscoWorks.
If the Proxy Server requires authentication, you must enter Proxy Server Username and Password.
Do you need to enter the Proxy Server Username and Password? (Press 'y' for Yes or 'n' for No)
n
Please specify Cisco.com credentials to connect to Cisco.com
Enter Cisco.com Username: aserov
Enter Cisco.com Password:
Loaded VDS  Properties..
Number of packages to be downloaded = 1
None of the packages that you have specified for rme are available for download.
I can download package SharedNetconfigIOSXR manualy thru the browser, but there is only version (1.0) and ASR(1.2) require (1.0.1)
C:\psu_download>psucli -p rme -pdep -src c:/psu_download/rme ASR
Checking for [rme] packages in c:/psu_download/rme ...
Package              Version    Depends on
ASR                  1.2        SharedCdaIOSXR(1.0)
                                SharedConfigNegatIOSRule(1.1)
                                SharedInventoryRouter(2.2.7)
                                SharedNetshowIOS(2.0.3)
                                SharedConfigNegatIOSXRRule(1.0.1)
                                SharedCredentialUpdaterIOSRule(1.2)
                                SharedDcmaIOSXR(1.0.2)
                                SharedPollerRouter(1.0)
                                SharedCredentialUpdaterIOSXRRule(1.0.1)
                                SharedCfgEditNegation(1.0)
                                SharedNetconfigIOS(2.1)
                                SharedSwimIOS(2.2.12)
                                SharedNetshowIOSXR(1.0)
                                SharedDcmaIOS(2.1.8)
                                SharedSwimIOSXR(1.0.3)
                                LibInventory(2.2.11)
                                SharedCdaIOS(2.0)
                                SharedCfgEditDiff(1.2)
Here is the location to download the packages directly fro, cisco.com for RME version 4.1
http://www.cisco.com/cisco/software/release.html?mdfid=280915376&flowid=5143&reltype=latest&relind=AVAILABLE&release=4.1.1&softwareid=280775121&sortparam=8
In case after downloading the correct packages, it still failed with the same inconsistency errors, then I will suggest you to open TAC case to get the device packages issue corrected. In this TAC will replace all the device packages from good know server to fix the issue.
Gaganjeet
