Packet Tracer Help! Ping Failure.
zanttila1
Hello Cisco community,
I am having a little trouble with my network configuration. I have set up everything to my knowledge, but still run into a ping failure. The computers from switch 2 to switch 4 are not connecting correctly. I am wondering if it has to do with access control list. I have DHCP set on my S4 and Static set on my S2. If someone can help me out that would be awesome! :)
-I need to ping from all devices.
-If there are any tips on improving my set-up or configuration that would be appreciated :)
Nithyanandan P
Unable to open file in Packet tracer version 6.1.0.0120. Kindly share the created Packet capture version/network setup with configurations.
This is packet tracer 6.2. You will have to update your packet tracer (which would be a good idea to begin with)
I have taken source 192.168.20.2 (SW2 Accounting PC) and destination 192.168.10.11 (SW4 Employee2 PC) for troubleshoot.
- L2 VLAN 20 was missing in SW3
- ACL was blocking out traffic in R1 so i removed it. Let me know the reason for ACL block
If you need any help, let me know.
Extended IP access list Accounting
10 deny ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255 (3 match(es))
Extended IP access list HR
10 deny ip 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255 (12 match(es))
PC>ping 192.168.10.11
Pinging 192.168.10.11 with 32 bytes of data:
Reply from 192.168.10.11: bytes=32 time=0ms TTL=127
Ping statistics for 192.168.10.11:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
PC>traceroute 192.168.10.11
Invalid Command.
PC>tracert 192.168.10.11
Tracing route to 192.168.10.11 over a maximum of 30 hops:
1 2 ms 1 ms 1 ms 192.168.20.1
2 0 ms 0 ms 0 ms 192.168.10.11
Trace complete.
PC>
PC>tracert 192.168.20.2
Tracing route to 192.168.20.2 over a maximum of 30 hops:
1 0 ms 0 ms 0 ms 192.168.10.1
2 1 ms 0 ms 0 ms 192.168.20.2
Trace complete.
PC>
