07-14-2022 03:53 PM
I have been taking a Packet Tracer course, and now I come across this guided activity: Packet Tracer - Troubleshoot a Wireless Connection
It tells me the following information:
"Before you can troubleshoot the problem, you need to understand which devices are affected. This is useful in determining if a single computer has a fault or if the entire network or parts of the network are affected.
A good way to test Internet connectivity is to verify that the hosts can access a website, such as www.cisco.pka.
When you have finished all the tasks, the Next button at the bottom will be enabled.
Click Next to continue thereafter.
You can use ping, tracert, or your web browser to try to reach www.cisco.pka"
But pinging or tracerting it, or trying it in the web browser gives me mixed results, and I think that's all I need to do for this part. However, I don't know let me advance to the next section.
It is worth mentioning that the course is in English and what I have done is based on my translation
03-29-2024 04:03 PM
Me pasa exactamente igual no se como avanzar.
03-30-2024 12:01 PM
Publique su archivo comprimido (ZIP) del proyecto Packet Tracer (.pkt)...
03-30-2024 12:06 PM
Estimado Georg muchas gracias por su respuesta. Pude lograrlo! solo cargue nuevamente el mismo zip y todo funciono. Gracias!!
