08-13-2015 02:49 PM
HI I am trying to do some packet captures on a tunnel interface and wanted to ask a few questions.
Details are as follows:
Router : ASR1002-X
Version: "bootflash:asr1002x-universalk9.03.10.05.S.153-3.S5-ext.SPA.bin"
Was trying to run packet capture based on the information as on the below link.
https://supportforums.cisco.com/document/29616/utilizing-new-packet-capture-feature
But wanted to check if this is capable to get the desired information if the interface of interest is a Tunnel interface with details as below?
Tunnel537 is up, line protocol is up
Hardware is Tunnel
Description: ### VPN Tunnel ###
Internet address is xxx.xxx.xxx.xxx/30
MTU 17868 bytes, BW 100 Kbit/sec, DLY 50000 usec,
Encapsulation TUNNEL, loopback not set
Keepalive set (10 sec), retries 3
Tunnel source aaa.aaa.aaa.aaa (Loopback53), destination bbb.bbb.bbb.bbb
Tunnel Subblocks:
src-track:
Tunnel537 source tracking subblock associated with Loopback53
Set of tunnels with source Loopback53, 2 members (includes iterators), on interface <OK>
Tunnel protocol/transport GRE/IP
Key disabled, sequencing disabled
Checksumming of packets disabled
Tunnel TTL 255, Fast tunneling enabled
Tunnel transport MTU 1476 bytes
Tunnel transmit bandwidth 8000 (kbps)
Tunnel receive bandwidth 8000 (kbps)
Last input never, output never, output hang never
Last clearing of "show interface" counters 1d09h
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/0 (size/max)
2771530 packets input, 619976946 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
2770869 packets output, 618159879 bytes, 0 underruns
0 unknown protocol drops
also when trying to run the following command it is not being accepted. Any reason why or a workaround for it?
Router#monitor capture point ip ?
% Unrecognized command
Any advise on this will be much appreciated.
Thanks in advance.
08-14-2015 07:21 AM
Anyone can advise on this please?
Thanks in advance
