Parameterized templates
Siebe Brouwer
Visitor
I need to change the hostname on a few switches, so I want to the the Parameterized templates in NetConfig.
I've used the following parameter file:
<DEVICE NAME = mySwitch>
<CMDPARAM NAME = hostName>
<value>mySwitch</value>
</CMDPARAM>
</DEVICE>
My template:
hostname $hostName
But the command that is sent to the switch is:
hostname mySwitch.0
Note the .0 at the end. That's not very pretty. Has anyone seen this before?
Kind regards,
Siebe
10 Replies 10
Joe Clarke
I have not. What version of RME are you using?
jedavis
Level 7
Level 7
I just ran into the same issue. RME 4.0.5.
f0/21-22
27
CLI Output
interface range f0/21-22.0
% Invalid input detected at '^' marker.
TSTS02(config)#
switchport access vlan 27
TSTS02(config)#
Interesting. I noticed in the CLI output above that the .0 was only on the first parameter. So I added a comment line with a dummy parameter before that in my template.
X
f0/21-22
27
The result is still this:
CLI Output
! X for Netconfig.0 problem
TSTS02(config)#
TSTS02(config)#
TSTS02(config)#
Please enable ConfigJob debugging under RME > Admin > System Preferences > Loglevel Settings, re-run your job, then post the Netconfig job directory under /var/adm/CSCOpx/files/rme/jobs/NetConfigJob (Solaris) or NMSROOT\files\rme\jobs\NetConfigJob (Windows).
It has something to do with the hyphen. If I take it out of the parameter, it works. If I put a space on either side of the hyphen it also works.
However, I posted the [edited] directory of a failed job.
I think I see the bug. However, I cannot post code on the forum. It will take me some time to test this patch, but if you would like to open a service request with TAC, I can send you the patch to try out. Just tell the engineer who gets your SR to contact me.
Case 607136311
I sent the patch to the engineer you owns the SR. The problem is the way the values are being parsed. The trick is that the line ends with "-22". The parser treats most characters as ordinary characters. However, the '-' was left as a default character. Because of that, when the '-' precedes a numeric value, the resulting string is parsed as a number (-22 in this case). The parser returns numbers in double precision format, thus -22 becomes -22.0.
I have fixed this problem, and local tests show the solution to be effective.
That did the trick Joe.
CLI Output
interface range f0/23-24
TSTS02(config-if-range)#
switchport access vlan 4
Thanks for the patch!
