Ciscoworks V2.6 Device discovery stopped
Hello all.
I'm running CW2.6 which was upgraded from 2.5, and had a license change from restricted to unresticted on 10 Sept. Recently (3 Oct), Campus (ver 4.0.6) has stopped doing a device discovery at either its scheduled time, or on demand.
Any sugestions on how to get it going again please.
To add to yjdabear's reply, your DEVICESROOT property in DeviceDiscovery.properties is:
C:\PROGRA~1\CSCOpx\campus\lib\classpath
This needs to be a valid directory with correct contents. Check to make sure this directory exists (i.e. that C:\PROGRA~1\CSCOpx is your true NMSROOT), and check the permissions. casuser or casusers must have full control.
7 Replies 7
I've tried stopping crmdmgtd, renaming DeviceDiscovery.Properties.orig to DeviceDiscovery.Properties, change the file path within the file, and restart crmdmgtd.
It now notifies campus to start a discovery, but immediatley shows as idle.
Any suggestions please.
Bernie
Thanks yjdabear.
I have done that twice now, but with no sucess.
I've attached the discovery log if this helps.
Bernie
To add to this, the process status report shows this
33. DeviceDiscovery Failed to run 0 -2 1073741822 N/A 23/10/2007 14:29:11 Not applicable Application failed or was registered incorrectly.
Bernie
Thank you both for your time and pactience.
It worked on the 5th attempt on copying/renaming the DeviceDiscovery.properties file
For reference, I used DEVICESROOT=C:\\PROGRA~1\\CSCOpx\\campus\\lib\\classpath
Love to know what corrupted the file as no changes were made to the system near the 3rd Oct.
Bernie
