passing all traffic through VPN tunnel
part of the config cisco router office 2:
interface Tunnel1
 description "Internet Tunnel"
 bandwidth 1000
 ip address 172.30.2.226 255.255.255.0
 ip mtu 1400
 ip nhrp authentication XXX
 ip nhrp map 172.30.2.200 public IP address office 3
 ip nhrp network-id 100000
 ip nhrp holdtime 360
 ip nhrp nhs 172.30.2.200
 ip tcp adjust-mss 1300
 delay 1000
 tunnel source GigabitEthernet9
 tunnel destination public IP address office 3
 tunnel key 100000
 tunnel protection ipsec  xxxxxxxx
interface GigabitEthernet9
 description "To Internet "
 ip address public IP address office 2
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 no cdp enable
interface GigabitEthernet4
 switchport access vlan 20
 no ip address
interface Vlan20
 description "Users Vlan"
 ip address 192.168.226.1 255.255.255.0
 ip nat inside
router eigrp 100
 network 1
 network 2
 network 172.30.2.0 0.0.0.255
 network 192.168.226.0
 passive-interface Vlan20
ip nat inside source list 100 interface GigabitEthernet9 overload
ip route 0.0.0.0 0.0.0.0 public IP address office 2
part of the config cisco router office 3:
interface Tunnel1
 bandwidth 15000
 ip address 172.30.2.200 255.255.255.0
 no ip redirects
 ip mtu 1400
 no ip split-horizon eigrp 100
 ip nhrp authentication xxx
 ip nhrp map multicast dynamic
 delay 1000
 tunnel source GigabitEthernet0/0/0
 tunnel mode gre multipoint
 tunnel key 100000
interface GigabitEthernet0/0/0
 encapsulation dot1Q
 ip address public IP address office 3
I would like to ask if it is possible and if so, how to change the configuration of the two Cisco routers in office 2 and 3 so that all traffic from office 2  to the internet goes through the tunnel. I would like office 2 users to go online from Cisco ASA in office 3.
At present, only traffic to private networks passes through the tunnel.
21 Replies 21
thank you for the advice!
Now I've explored traffic through Cisco ASA in office 3.
Internal address cisco ASA in office 2 is  192.168.108.2
From laptop in private lan in office 2
In Real-time log viewer on cisco asa I can view that I can successfully ping 192.168.108.2
But I cannot ping external ( public) IP address.
No any traffic go to cisco ASA from laptop when try ping to any public address.
I'm not sure internet traffic from office 2  goes through the tunnel!!!
Please share the router configuration (HUB) which is seating in the Office3.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
I'm not sure  that internet traffic goes through the tunnel!!!
Now I try tracert from laptop in office 2
 tracert 192.168.108.2 ( internal address Cisco ASA, this address NAT ing to publlic address ASA)
1 ........... 192.168.226.1
2. ..........172.30.2.200
3. .......... 192.168.200.2
4. ........... 192.168.108.2
 tracert 194.145.63.12  ( public ip address to one internet site)
1. ........ 192.168.226.1
2. 192.168.226.1 reports: Destination host unreachable
For testing purpose add an IP route on the spoke:
Ip route 0.0.0.0 0.0.0.0 172.30.2.200
As you are use EIGRP so it is not reconnected due to extra configuration needed by static route but it is for testing purposes only.
Deepak Kumar,
now add ip route 0.0.0.0 0.0.0.0 172.30.2.200
ping 8.8.8.8 from laptop
Request time out.
currently, users from office 1 with network 192.168.202.0/24 are connecting via private network 10.141.x.x  with tunnel 1 of cisco hub, they have access to private networks and have access to the internet via cisso  ASA, user from office 2 with network 192.168.226.0/24 are connecting via Internet with tunnel 0  of cisco hub, they have access to private networks but they  do not have access to internet.
I see a difference between tunnel configuration>  ip policy route-map ROUTE_THROUGH_ASA in tunnel 1,
for any case I add ip policy route-map ROUTE_THROUGH_ASA in tunnel 0, but the result is the same, user in office 2 have not internet access.
This is HUB1 running-config:
HUB_1#show run
Building configuration...
Current configuration : 37921 bytes
! Last configuration change at 11:06:26 EEST Thu Oct 10 2019 by xxx
! NVRAM config last updated at 11:05:42 EEST Thu Oct 10 2019 by xxx
version 15.5
no platform punt-keepalive disable-kernel-core
hostname HUB_1
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable secret 5
no aaa new-model
clock timezone EET 2 0
clock summer-time EEST recurring last Sun Mar 3:00 last Sun Oct 4:00
ip name-server 192.168.100.10 192.168.100.11
ip domain name xxx.local
subscriber templating
crypto pki trustpoint TP-self-signed-0000000000
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-0000000000
 revocation-check none
 rsakeypair TP-self-signed-0000000000
crypto pki certificate chain TP-self-signed-0000000000
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
username xxxx privilege 15 secret 5
redundancy
 mode none
vlan internal allocation policy ascending
crypto isakmp policy 2
 encr aes 256
 authentication pre-share
 group 2
crypto isakmp key xxxxx address 0.0.0.0
crypto isakmp keepalive 10 5 periodic
crypto ipsec transform-set ESP_AES256_SHA esp-aes 256 esp-sha-hmac
 mode tunnel
crypto ipsec fragmentation after-encryption
crypto ipsec profile Cisco_xxx
 set transform-set ESP_AES256_SHA
interface Tunnel0
 bandwidth 15000
 no ip redirects
 ip mtu 1400
 ip nhrp authentication DMVPN_WW
 delay 1000
 tunnel source GigabitEthernet0/0/0.486
 tunnel key 100000
 tunnel protection ipsec profile Cisco_xxx
interface Tunnel1
 description "Private LAN   Tunnel"
 bandwidth 20000
 ip address 172.30.1.200 255.255.255.0
 no ip redirects
 ip mtu 1400
 delay 1000
 tunnel source GigabitEthernet0/0/0.141
 tunnel key 100000
 no ip address
 negotiation auto
 no cdp enable
interface GigabitEthernet0/0/0.141
 description " network 141"
 encapsulation dot1Q 141
 ip address private IP address for tunnel for VPN  office 1  255.255.255.0
interface GigabitEthernet0/0/0.486
 encapsulation dot1Q 486
 ip address public IP address office 3 for VPN tunnel  255.255.255.248
interface GigabitEthernet0/0/1
 ip address public IP address for LAN ( uses for NAT Cisco ASA) 255.255.255.252
 negotiation auto
interface GigabitEthernet0/0/2
 no ip address
 negotiation auto
interface GigabitEthernet0/0/2.9
 description telepresense
 encapsulation dot1Q 9
 ip address 192.168.11.2 255.255.255.0
 standby 1 ip 192.168.11.1
interface GigabitEthernet0/0/2.200
 encapsulation dot1Q 200 native
 ip address 192.168.200.1 255.255.255.0
 vrf forwarding Mgmt-intf
 no ip address
 shutdown
 negotiation auto
interface Vlan1
 no ip address
 shutdown
router eigrp 100
 network 10.0.0.0 0.0.3.255
 network 10.10.100.0 0.0.0.255
 network 172.30.1.0 0.0.0.255
 network 192.168.11.0
 network 192.168.200.0
 redistribute static route-map STATIC_TO_EIGRP100
 passive-interface default
 no passive-interface Tunnel0
 no passive-interface Tunnel1
 no passive-interface GigabitEthernet0/0/2.200
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0/0/0
ip route 10.0.0.0 255.255.252.0 192.168.200.2
ip route 10.1.200.0 255.255.255.0 192.168.200.2
ip route 10.10.10.0 255.255.255.0 192.168.200.2
ip route 10.10.100.0 255.255.255.0 192.168.200.2
ip route 10.20.200.0 255.255.255.0 192.168.200.2
ip route 10.30.14.22 255.255.255.255 192.168.200.2
ip route 10.141.0.0 255.255.0.0 10.141.2.1
ip route 172.16.1.10 255.255.255.255 192.168.200.2
ip route 172.16.141.0 255.255.255.240 192.168.200.2
ip route 172.17.2.0 255.255.255.0 192.168.200.2
ip route 192.168.0.21 255.255.255.255 192.168.200.2
ip route 192.168.64.0 255.255.255.0 192.168.200.2
ip route 192.168.95.0 255.255.255.0 192.168.200.2
ip route 192.168.96.0 255.255.240.0 192.168.200.2
ip route 192.168.129.55 255.255.255.255 192.168.200.2
ip route 192.168.255.0 255.255.255.0 192.168.200.4
ip route public IP address 255.255.255.224 public IP address
ip access-list standard STATIC_ROUTES
 permit 10.30.14.22
 permit 192.168.0.21
 permit 172.16.1.10
 remark "Terminal Server"
 permit 192.168.129.55
 remark "Static routes redistributed in EIGRP 100"
 permit 192.168.96.0 0.0.15.255
 permit 172.16.141.0 0.0.0.15
 permit 10.10.10.0 0.0.0.255
 permit 192.168.64.0 0.0.0.255
 permit 10.1.200.0 0.0.0.255
 remark "Avaya IP Phone network"
 permit 192.168.42.0 0.0.0.255
 remark "Route to DMZ network"
 permit 172.17.2.0 0.0.0.255
 remark " users 1 network"
 permit 10.20.200.0 0.0.0.255
 permit 10.10.100.0 0.0.0.255
 remark "Voice"
 permit 10.0.0.0 0.0.3.255
ip access-list extended SOURCE_ROUTING
 deny   ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
 permit ip 192.168.202.0 0.0.0.255 any
 permit ip 192.168.203.0 0.0.0.255 any
 permit ip 192.168.204.0 0.0.0.255 any
 permit ip 192.168.208.0 0.0.0.255 any
 permit ip 192.168.209.0 0.0.0.255 any
 permit ip 192.168.210.0 0.0.0.255 any
 permit ip 192.168.211.0 0.0.0.255 any
 permit ip 192.168.212.0 0.0.0.255 any
 permit ip 192.168.213.0 0.0.0.255 any
 permit ip 192.168.214.0 0.0.0.255 any
 permit ip 192.168.215.0 0.0.0.255 any
 permit ip 192.168.216.0 0.0.0.255 any
 permit ip 192.168.217.0 0.0.0.255 any
 permit ip 192.168.218.0 0.0.0.255 any
 permit ip 192.168.219.0 0.0.0.255 any
 permit ip 192.168.220.0 0.0.0.255 any
 permit ip 192.168.221.0 0.0.0.255 any
 permit ip 192.168.222.0 0.0.0.255 any
 permit ip 192.168.223.0 0.0.0.255 any
 permit ip 192.168.224.0 0.0.0.255 any
 permit ip 192.168.225.0 0.0.0.255 any
 permit ip 192.168.226.0 0.0.0.255 any
 permit ip 192.168.227.0 0.0.0.255 any
logging host 192.168.96.254
access-list 1 remark "SNMP allowed"
access-list 1 permit 192.168.96.254
access-list 110 permit ip any any
access-list 110 permit ip any public IP address 0.0.0.31
access-list 110 deny   ip 10.0.0.0 0.255.255.255 any
access-list 110 deny   ip 172.16.0.0 0.15.255.255 any
access-list 110 deny   ip 192.168.0.0 0.0.255.255 any
access-list 110 deny   ip 127.0.0.0 0.255.255.255 any
access-list 110 deny   ip host 255.255.255.255 any
access-list 110 deny   ip host 0.0.0.0 any
access-list 110 deny   ip any any log
route-map ROUTE_THROUGH_ASA permit 1
 match ip address SOURCE_ROUTING
 set ip next-hop 192.168.200.2
route-map NAT permit 10
 match ip address 180
route-map STATIC_TO_EIGRP100 permit 10
 match ip address STATIC_ROUTES
snmp-server community DCOMM RO 1
control-plane
line con 0
 login local
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 exec-timeout 480 0
 privilege level 15
 logging synchronous
 login local
 transport input ssh
line vty 5 15
 privilege level 15
 login
 transport input ssh
ntp master 4
ntp server pool.ntp.org
ntp server 80.96.120.253
pnp profile pnp_redirection_profile
 transport http ipv4 127.0.0.1 port 80
end
the solution to the problem was so easy :)))
config
ip route public addresses on cisco HUBS in office 3 /30 IP address gateway ISP office 2
ip route 0.0.0.0 0.0.0.0 172.30.2.200 ( ip address tunnel on HUB 1)
ip route 0.0.0.0 0.0.0.0 172.30.4.200 5 ( ip address tunnel on HUB 2)
the first routing is only to work  VPN tunnels between office 2 and office 3
the second and third routing  pass  internet traffic through the tunnels and after that  through Cisco ASA
