PBR command, 'ip policy route-map' does NOT exist.
eeebbunee
Hello Engineers,
Our company are using Cisco 3750X series switch.
Current SW version is 15.0(2)SE10a and image is 'C3750E-UNIVERSALK9-M'.
Today I found that there is no command about 'ip policy route-map'.
I couldn't apply my route-map to inter-vlan because of no command.
Weird thing is that other Core switch in other site office, I can config ip policy~ command even though it has exactly same model and image file.
Can you tell me what did I miss?
Otherwise, is there other way that I can apply my route-map config to interface?
Actually I found command,
 switch(config-route-map)# set interface vlan #
If I config this command rather than ip policy~, do you think it is work as same as what I expected?
Thank you for your reply.
fbeye
Level 4
Level 4
If I am correct I believe you need the IPSERVICES image for the Catalyst to support PBR.
What does your ‘sh license’ state?
