pearson vue problem account
valiant-aninon
I have a Problem, in Pearson Vue account I think they don’t accept the letter ‘ñ’ since it is a special character. I recently scheduled my exam on August 19, my full name is VALIANT ANIÑON
and in pearson vue account it appears to be VALIANT ANINON, i think it automatically typed the letter Ñ to N, my problem is, are you gonna make my certifications ANIÑON if I will pass my Exam? Can you edit my name in pearson vue? Thank you in advance
I read on another forum, due to the system design, all names with special characters/diacritics cannot be use when creating a certification profile and can trigger an issue upon exam registration.
Having said this, it is recommended to proceed in using "n" as Pearson Vue assured that they will acknowledge all names with special characters/diacritics on your valid identification and they should not encounter any issues on the exam day.
If in doubts, suggest to open support case with Pearson
For your certificate, I found that the name on your certification profile will mirror the name on your certificate.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Martin L
Also check CLN community Cert and CCNA forums at
https://learningnetwork.cisco.com/s/communities
https://learningnetwork.cisco.com/s/topic/0TO3i0000008jYHGAY/ccna-certification-community
Regards, ML
**Please Rate All Helpful Responses **
