Nexus 9000 high cpu/memory syslog
Veroniks23
Hi everyone!
are you familiar if there is a syslog about high cpu/memory utilization on a Cisco nexus 9000?
if there is - how does it looks?
I want to use it on my syslog server and I can’t find any info about that
thank you
marce1000
         - It will not throw specific messages concerning high CPU , for troubleshooting take a look here : https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/troubleshooting/guide/b_Cisco_Nexus_9000_Series_NX-OS_Troubleshooting_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_Troubleshooting_Guide_7x_chapter_010001.html#reference_8EB0CA5ED...
 M.
7 Replies 7
share output of this command
NSK# show system internal processes cpu  5
thank you but that’s not what I meant.
I wanted to know if there’s a high cpu/memory
on my nexus - if a syslog message about that will show up and how does it looks
we can not see wind but we see it effect,
so we can not see CPU/Memory Utilize BUT we can see
1-STP flapping
2-routing flapping
3-netwrok drop
4-slow SSH/Telnet response
all indicate that there is issue with CPU/Memory and here there are many commend we must enter to see
CPU utilize
CPU history
top 5 process utilize CPU
and do necessary step to stop first cause of high utilize.
hello, can you tell me how to kill or stop the "top" process that has started by this command?
marce1000
 M.
Thank you!!
Is this the same for ISR 4431 routers?
         - FYI : https://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/15095-highcpu.html
 M.
