Perimeter switch Migration
M.Sultan
Hello guys
i'm in stage of migrating the old Cisco 2960 switches replacing them with new version, the 2960 switches placed facing to the ISP has perimeter role at the moment, does any one has any idea from where to start and how ?
Thank you
balaji.bandi
there is some steps i have suggested below post - have a look that should be work for you.
depends on your switch act as layer 2 or layer3. (there will be small service interruption so suggest to do in maintenance window)
https://community.cisco.com/t5/switching/cat-6500-core-switch-migration/m-p/5113908#M564899
Note : do not turn off old switch after migration until you see stability of the new switch config in case you required to roleback - make a plan.
BB
balaji.bandi
BB
Mark Elsen
  - If it's only a software upgrade ; then there is not much extra work ; don't forget to save the running configuration
     to startup configuration and save the running configuration to an external repository too in case of calamities ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
