PERL scripting | CISCO
Josiah Inubio
Hi All,
I'd like to know if there's any reference for cisco regarding perl scripting?
Scenario:
Using perl scripting to communicate with the router to get info (ex. sh int, ping, mrtg, etc) and it should be printed out via web based (html)
5 Replies 5
Joe Clarke
Nothing official, but have a look at the Net::Telnet::Cisco module as well as the netdisco tool (Perl-based).
http://search.cpan.org/~joshua/Net-Telnet-Cisco-1.10/Cisco.pm
https://metacpan.org/pod/App::Netdisco
Hi Joseph,
How can I start building this platform? My plan was to create an HTML website or MS Access to integrate into the router to get info and printed via html or in access
I think you should download and install the components of Netdisco.  If you look at the website to which I pointed you, you can checkout the demo.  See if that meets your needs.  I think it might as it will provide a lot of the basic network information you may want.  From there, you can decide if you need to extend its capabilities with your own custom Perl code.
is it possible that Netdisco will initiate or run if we have our aggregate routers / PE routers that isn't cisco?
Absolutely.  Netdisco is not a Cisco-only management platform.  Netdisco can handle gear from any vendor that supports SNMP.
