PI 3.0 can't do custom mib polling threshold and dashlet
sp-netops
Folks,
I have upgraded to PI 3.0.2, however still the same.
I can upload mibs fine, CISCO_RF_MIB for instance, which is to check the router rsp redundant mode. However there is no threshold to configure so I can't set up alarms based on the polling results as LMS does.
I couldn't setup generic dashlet either, as the document says I need to set up custom polling first, which I did.
I have to say, PI 3.0 is still full of bugs  not suitable for migration from LMS 4.2.5.
Cheers,
Jing
5 Replies 5
sp-netops
Another issue is that when I do inventory report, modules in the router will never appear.
sp-netops
This bug is a show stopper for me. I can't believe Cisco couldn't do proper coding!
sp-netops
No one has this issue here?
david_nyring
i agre with you i also havn't got custtom mib polling to work  since i try pi in version 2.2.
so on that part we still need lms or 3 party software to get it working proberly :(
if i make a wired detailed device inventor it tells me what module i have in my 6500
Thanks for your reply. Hopefully someone can explain why as nothing can be found in documents.
